WiFi-2 WebWhip Long-Range Wi-Fi Receiver805
| http://shakespeare-ce.com/marine/product/wifi-2-webwhip-long-range-wi-fi-receiver/ WiFi-2 WebWhip Long-Range Wi-Fi Receiver Long-Range Wi-Fi Receiver If you ever get a call from someone who says they want an antenna to pickup open Wifi Hotspots (get free access to the internet in a nuttshell) .... See this product. Two calls today / thinking they could use any antenna to access free wifi hotpots - this is a purpose built solution runs about 250.00 to 350.00 in the market. WebWhip™ Stay connected to the world of information where ever you go. Increase the coverage of public hotspots with the WebWhip, our fully integrated Wi-Fi antenna, radio and router, for hassle-free internet reception on your boat, RV, cabin or AnyWhere® else. Access the internet directly through LAN or wirelessly, by connecting WebWhip to any standard Wi-Fi router. Manage the network without any software installation through any device with a web browser. Simple, powerful, AnyWhere. Long range WiFi reception on land or water Connect straight to your computer through an Ethernet cable Easy to create local Wi-Fi hotspot with any standard Wi-Fi router Single wire for power and data. No power consumed from connected device Simple, intuitive set-up and operation. No software installation required Manage device easily on any device with an internet browser IPX5 water proof* when installed correctly *IPX5 water proof: International Protection Marking or Ingress Protection Marking, classifies and rates the degree of protection provided against intrusion dust, accidental contact, and water by mechanical casings and electrical enclosures published by the International Electrotechnical Commission. 5 indicates Water jets: Water projected by a nozzle (6.3 mm) against enclosure from any direction shall have no harmful effects. Data Sheet: http://shakespeare-ce.com/marine/wp-content/uploads/sites/4/2016/04/WebWhip2-SpecSheet.pdf User Guide / Admin Manual http://shakespeare-ce.com/marine/wp-content/uploads/sites/4/2016/04/WebWhip2-Manuals.pdf http://shakespeare-ce.com/marine/product/wifi-2-webwhip-long-range-wi-fi-receiver/ |
| Post 1 IP flag post | ||
