FortiVoice POTS Lines w/ Grandstream GXW4108
See here:
https://www.fortivoice.com/sites/default/files/productdatasheets/FortiVoice_grandstream.pdf
Fortinet Support (866) 648-4638
Grandstream GXW4108
The Grandstream GXW- Series Analog 8 FXO IP Gateways are designed and tested for full interoperability with leading IP-PBXs, Softswitches and most SIP-based environments.
Grandstream GXW4108 Summary
Grandstream GXW4108 - Designed and tested for full interoperability with leading IP-PBXs, Softswitches and most SIP-based environments, the GXW technology ensures manageability, a simple configuration, superb voice and video quality and feature rich functionality. The GXW series also offers a video surveillance port and is the only small business gateway in the industry that provides a video surveillance option. GXW Series IP Gateway is based on open industry standards.
The GXW FXO IP Analog Gateway series offers the small enterprise, SOHO, remote offices and multi-location enterprises a cost-effective, easy to deploy VoIP FXO solution. The GXW4108 series allows any business to seamlessly connect multiple locations with up to 8 PSTN lines, to an IP PBX system, or with an existing traditional phone system.
Designed and tested for full interoperability with leading IP-PBXs, soft-switches and SIP-based environments, the GXW technology ensures manageability, a simple configuration, superb voice and video quality and feature rich functionality. The GXW FXO IP Analog Gateway series is based on open industry standards.
Grandstream GXW4108 Key Benefits
8 FXO port media gateways
Video surveillance port
External power supply
Two RJ-45 ports 10/100 Mbps (switched or routed)
TFTP and HTTP firmware upgrade support
Multiple SIP accounts (choice of 3 profiles per account)
Programmable PSTN line settings for different countries/regions
1 or 2 stage dialing
Caller ID
G.168 - echo cancellation
Flexible DTMF transmission: In Audio, RFC2833, SIP Info or any combination of the 3
Selectable, multiple LBR coders per channel
T.38 Fax compliant
____________________________________________________________
MailEdge.net | Email Secured
Full Domain Spam and Email Threat Protection, Start FREE
