https://support.sonicwall.com/kb/sw6617
UTM - CFS: How to exclude a computer from SonicWALL Content Filtering Service (CFS) (SW6617)
Title
Resolution
Article Applies To:
Affected SonicWALL Security Appliance Platforms:
Gen5: NSA E7500, NSA E6500, NSA E5500, NSA 5000, NSA 4500, NSA 3500, NSA 2400, NSA 240
Gen4: PRO series: PRO 5060, PRO 4100, PRO 4060,PRO 3060, PRO 2040, PRO 1260
TZ series: TZ 210, TZ 210 Wireless, TZ 190, TZ 190 W, TZ 180, TZ 180 W, TZ 170, TZ 170 W, TZ 170 SP, TZ 170 SP Wireless, TZ 150, TZ 150 W, TZ 150 Wireless (RevB)
Affected Firmware versions: All Gen5 and Gen4 firmware versions (SonicOS Standard and Enhanced)
Affected Services: Content Fitler Exclusion list.
OverView:
IP address ranges can be manually added to or deleted from the CFS Exclusion List. Content filtering is disabled for IP addresses in the CFS Exclusion List. These address ranges are treated as trusted domains. Select Enable CFS Exclusion List to enable this feature.
Click To See Full Image.
The Do not bypass CFS blocking for the administrator checkbox controls content filtering for administrators. By default, when the administrator (“admin” user) is logged into the SonicOS management interface from a system, CFS blocking is suspended for that system’s IP address for the duration of the authenticated session. If you prefer to provide content filtering and apply CFS policies to the IP address of the administrator’s system, select the Do not bypass CFS blocking for the administrator checkbox.
Procedure:
To add a range of IP addresses to the CFS Exclusion List, follow these steps:
Step 1 Login to the SonicWALL Management Interface
Step 2 Go to Security Services > Content Filter
Step 3 Select the Enable CFS Exclusion List checkbox.
Step 4 Click Add. The Add CFS Range Entry window is displayed.
Step 5 Enter the first IP address in the range in the IP Address From: field and the last address in the IP Address To: field.
*** Go here to see the full Tech Bulletin
MailEdge.net
Full Domain Spam Filtering
LiquidLayer.net
Global Web Hosting
