MAC Mini USB Storage Keep Drive Spinning201
| If you ever wake up your MAC Mini and it notes a "Drive Ejection Error" and your USB Drive is disconnected then reconnects ... check this note and utility out. Keep Drive Spinning is an applet that makes sure that a connected drive never goes to sleep (that is, that it never spins down). Normally this can be controlled using the Energy Saver preference pane in System Preferences, and that should be your first resort in dealing with the problem, rather than this or any other third party software. However, some external drives (e.g. Western Digital's MyBook drives) do not respect the System Preferences settings, so for them an alternative like this is needed. http://www.macupdate.com/app/mac/31158/keep-drive-spinning |
| Post 1 IP flag post | ||
| Jon Stovell Software http://web.me.com/jonstovell/personal/Software.html Tag Folders Simple, flexible, powerful file tagging, right in Finder. Front Row on the Big Screen Complete control over which display Front Row plays on. New Sticky Make a new Dashboard sticky note in one click from the Dock. Quit A command line tool to politely quit applications from Terminal. Unlike killall, quit lets an application do a proper quitting procedure instead of forcibly terminating it. Keep Drive Spinning Makes sure that a selected drive does not go to sleep unexpectedly. For use with certain external drives that don’t respect Mac OS X’s power management settings. StickiesSync Keep your Stickies.app sticky notes in sync across your Macs. JournlerSync Keep your Journler journal in sync across your Macs. Free Stuff for Mac OS X |
| Post 2 IP flag post | ||
1This topic is archived. Start new topic?
