LiquidLayer.net | Tech
IntelliTone™ Pro Toner and Probe Wire Finder190
LiquidLayer private msg quote post Address this user
Get advanced vision for locating cables more effectively at patch panels, switches, termination blocks, or hidden within bundles. Our new IntelliTone Pro Toner and Probe Kits find the cables others can't.
The IntelliTone™ Pro Toner and Probe Series from Fluke Networks is the first toner and probe to offer digital and analog signaling all in one tool. That means it’s equipped with the most powerful cable location technologies for any work environment. Use digital mode to trace and locate data cabling safely and effectively on active networks. Use analog mode to isolate individual wire pairs, and trace voice, audio, and video cabling.
The IntelliTone™ Pro Toner and Probe Series from Fluke Networks gives you superior vision for locating cables hidden in floors, ceilings, walls, and in bundles. Its breakthrough digital technology makes it the first tool to tone and trace safely and effectively on active networks.
Digital toner and probe traces and locates cables on active network.
IntelliTone digital toning technology:
Ends cable location confusion, decisively rejects noise and false signals
Locates cables on active networks, even when terminated at a switch
Isolates cable and wiring within a bundle, despite cable bleed
Confirms cable location, verifies continuity, and detects faults (opens, shorts, and reversed pairs) in one step
SmartTone® analog toning technology:
Isolates individual wire pairs precisely by changing tone when shorted
Effectively traces and locates voice, audio, and video cabling
Only IntelliTone™ Pro Toners and Probes offer the powerful combination of digital and analog technologies to resolve common infrastructure problems that arise during installing, maintaining, and changing of your network.
Digital and analog toning in one tool.
Today’s media networks are more diverse than ever. Most buildings have a combination of telephone, twisted-pair data, coax, and security/alarm wiring. Verifying proper routing and termination of this diverse set of cabling types requires tools optimized for different frequencies, connector types, and work environments. Until now, no single tool has combined the right technologies to operate across all copper media types, and in all environments. IntelliTone Pro changes that by combining cutting-edge digital and analog signaling to locate and verify virtually any copper cable, regardless of application or environment.
When to use digital
IntelliTone Pro’s digital encoded signal should primarily be used on high-grade data cabling (Cat 5e/6/6a), and in active network environments. It operates at a high-frequency to match the higher frequency data the cable plant is designed to carry. This allows the tone to overcome competing data signals and aggressive low-frequency terminations of Ethernet switches. That means LAN cabling technicians can quickly zero in on the right cable during installations or troubleshooting.
Digital toning is especially helpful once the cable has been located as it displays cable wiremap and checks for shorts, opens and miswires. The IntelliTone Pro 200 probe has an RJ45 input port and CableMap feature, allowing it to be plugged directly into a patch panel or wall port. The benefit of this wiremap test is two-fold. It eliminates the need for both a toner to a wiremapper, and provides 100% confirmation that the right cable has been located.
When to use analog
IntelliTone Pro’s SmartTone analog toning can be used on voice-grade cabling (Cat 3 and below), as well as coax, security/alarm, and speaker wiring. These cables are optimized for lower frequency transmissions, and therefore are more easily isolated with a low-frequency tone. It should also be used in areas with relatively low interference from electronic devices. In high-interference environments, digital may still be a better choice.
SmartTone analog toning eliminates frustrating guesswork locating individual wire pairs during installations. The SmartTone analog signal will change ‘songs’ each time the pair under test is shorted together. This provides telecom technicians a decisive way to identify individual wire pairs before punching them down on a jack or a block, or when diagnosing voice transmission problems.
Isolate Terminated Cables
The IntelliTone™ Pro Toner uses the unique properties of twisted pair cabling to create a balanced signal that minimizes the effect of signal bleed. The smart digital signal processing in the IntelliTone™ Pro Probe clearly identifies this signal with audio and LED visual indicators, allowing you to rapidly isolate the correct cable from a bundle or on a patch panel. IntelliTone™ eliminates hours of cable confusion—and you can count on getting it right the first time.
Isolate Individual Wire Pairs
With traditional analog toners and probes, isolating individual wire pairs precisely can be almost impossible because of signal bleed between pairs. As a result, wire pairs are often routed and terminated incorrectly the first time.
Redoing incorrect terminations or pulling new wiring wastes tremendous amounts of time and money. IntelliTone Pro’s SmartTone analog technology cuts out the guesswork and improves accuracy by providing definitive confirmation when the pair under test is located. Just short the pair under test, and the audible tone will change its cadence. The difference is dramatic.
Modern network devices use aggressive termination schemes for cables connected to their ports. While this termination reduces noise and crosstalk in the cable, it can also absorb an analog toner signal, making the connected cable impossible to detect with an analog audio probe.
The result is that locating an unlabeled network can take hours with analog technology. Unlike analog signals, the IntelliTone digital signal stays strong despite common mode termination.
And the IntelliTone Pro Toner automates toning individual cable conductors, making it quick, efficient and safe to locate cables on active networks.
Source URL
Post 1 IP   flag post
General Information
Manufacturer/Supplier:
Fluke Networks
Manufacturer Part Number:
MT-8200-60A
Manufacturer Website Address:
www.flukenetworks.com
Brand Name:
Fluke Networks
Product Model:
MT-8200-60A
Product Name:
MT-8200-60A Cable Analyzer Kit
Marketing Information:
Get advanced SuperVision for locating cables more effectively at patch panels, switches, termination blocks, or hidden within bundles. Our new IntelliTone Pro Toner and Probe Kits find the cables others can't.
The IntelliTone Pro Toner and Probe Series from Fluke Networks is the first toner and probe to offer digital and analog signaling all in one tool. That means it's equipped with the most powerful cable location technologies for any work environment. Use digital mode to trace and locate data cabling safely and effectively on active networks. Use analog mode to isolate individual wire pairs, and trace voice, audio, and video cabling.
The IntelliTone Pro Toner and Probe Series from Fluke Networks gives you superior vision for locating cables hidden in floors, ceilings, walls, and in bundles. Its breakthrough digital technology makes it the first tool to tone and trace safely and effectively on active networks.
Product Type:
Cable Analyzer
Technical Information
Test Services:
High-Resolution Measurement
SmartTone Analog Technology
Controls/Indicators
Status Indicators:
3-level Battery Status Indicator
Miscellaneous
Package Contents:
IntelliTone Pro 200 Toner
200 Probe
Coax F-Connector Adapter
2 x RJ11
2 x RJ45 patch Cables
Test leads with alligator clips
Lanyards
Owners CD
Quick Start Guide
2 x 9 Volt Batteries
Post 2 IP   flag post
Watch Video Demo's Here
Post 3 IP   flag post
1271 3 3
This topic is archived. Start new topic?
